BD8-12kW-RH3三相储能逆变器
BD8-12kW-RH3三相储能逆变器拥有8kW,10kW,12kW三个功率规格选择,兼容单相负载和三相负载,支持100%不平衡带载,最大效率可达97.9%,适用于高端别墅、通信基站、游牧农场、居民用电等场景。
高效发电 收益更高
最大效率97.9%
支持一类负荷优先供电
支持满功率放电,电池充放电自动管理
安全智能 运维简单
支持柴油发电机接入
兼容铅酸和锂离子电池等多种高压电池接入
兼容防逆流功能
友好灵活 多样便捷
IP65高防护, 支持户外安装
具备电池反接保护
支持RS485/CAN/DRM(Wifi/4G可选)
手机/电脑智能监控,随时随地操作更便捷
BD8KTR-RH3BD10KTR-RH3BD12KTR-RH3
Input (PV)
Max. PV Input Power10.4kW13kW15.6kW
Max. PV Input Voltage  1000V
Max. Current per MPPT 12.5A
MPP Voltage Range180V ~ 850V
Number of MPP Trackers2
Number of String per MPPT1
Output (AC)
Max. Output Current12.7A15.9A19.1A
Rated Output Power8kVA10kVA12kVA
Rated Voltage400V, 3L + N + PE
Frequency 50Hz / 60Hz
Power Factor0.8 lagging~0.8 leading
THDi<3%
Output (EPS)
Max. Output Power 8.8kVA11kVA13.2kVA
Rated Voltage400Vac
Rated Current12.7A15.9A19.1A
Overload Capacity110%, 30S / 120%, 10S / 150%, 0.02S
Rated Frequency50Hz / 60Hz
Automatic Switching Time<20ms
THDu<2%
Battery
Battery Voltage Range125V ~ 600V
Max. Charging Voltage600V
Full Battery Voltage210V270V250V
Max. Charge / Discharge Current40A40A50A
Battery TypeLithium / Lead-acid
CommunicationRS485, CAN
Efficiency
Max. DC Efficiency 97.90%98.20%98.20%
European Efficiency 97.20%97.50%97.50%
MPPT Efficiency 99.50%99.50%99.50%
Battery Charge / Discharge Efficiency 96.60%96.70%96.80%
Communication
DisplayLCD
CommunicationStandard: RS485 / CAN / DRM
 Optional: WiFi / 4G
Standard Compliance
CertificatesCE, TÜV
General data
Dimensions (W x H x D)530 × 600 × 200 mm
Weight29kg
Operation Temperature-25℃ ~ +60℃
Cooling MethodNatural Cooling
Protection DegreeIP65
Noise Emission<35dB
Max. Operating Altitude2000m
Relative Humidity0~95%  (non-condensing)
TopologyTransformerless
Standby Power Consumption<3W
英威腾 BD8-12kW-RH3三相储能逆变器 V1.0 pdf 1.31 MB 2022-11-19
BD8-12KTR-RH3储能逆变器用户手册 V1.0 pdf 5.04 MB 2022-11-19
